Hi all.
I want to build a couple of wooden dining benches for our table. Space wise, benches will look a lot neater and fit a few more bums on seats (kids at least!).
I was thinking of either using old scaffold boards (cleaned and sanded), or (more likely) bringing in some oak planks (cut to size).
My other half's family live in the middle of rural Norfolk and have a 'wood farm' a 5-10 min walk away from their house. I've visited this and the shear amount of wood (planks, trunks, trees) is breathtaking. The in laws know the family who run this so it's not an issue them selling the cutting the wood for us and sending them up next time they visit.
Something like this:
Dimensions wise I was thinking of 1180mm length (just enough for it to slot under the table), 14" wide (12" or 13" would possibly suffice) and around 40mm thick.
After that (and this is stepping outside carpentry for a moment) I was wondering what the process for the steel legs would be - square as in the photo above. Can this be purchased in standard sizes, or would it be a case of visiting a metal works and getting them shape the steel for me?? Is there a rough guide to cost?
The only thing I've managed to find is from a firm selling on ebay:
These are powder coated (or you can purchase them pre treated) and cost £120 for the two.
I've absolutely no idea what to compare the prices to (they look a little more high end than I intended). I can't seem to locate a local firm that would do this type of steel (is it cold folded?)
After I have the steel legs/supports and wood would I drill holes in the steel and tap screw bolt 'plugs' (I bet someone mentioned this to be on here a while ago, but I've forgotten the term - essentially a metal rawl plug that you tap into wood then screw a bolt into).
Is this doable and cost effective (presuming I can get a decent price for the wood, it's the steel I'm worried about). This type of bench (and table) retail for a considerable amount of money.
Many thanks!
Many thanks!
