Screws or Nails?
10 Nov 2010
Kent
Should I use screws or nails to tack down 9mm ply to wooden floor boards that will be tiled on? And what size would suffice?
Thank-you
9mm WBP ply is no way near thick enough for o/boarding....
what condition is the f/boards in...are they "screwed" to joists every 200/300mm....
there is no deflection/bounce on it whats so ever......
either use a 6.5mm cement based backer board,...aquapanel/hardie/no more ply etc ..follow mfr inst re:fixing o/boarding...i.e..glueing/screwing..
or 15mm WBP ply screwed every 200/300mm into joists,but prime the underside and edges with sbr/acrylic primer proir to fixing down...
have a wee scoop about prevouis threads on here.. :wink:
