What sort of wooden floor is it? What sort of ply is it? 9mm isn't thick enough, 12mm is the minimum for over boarding. You should screw through into the joists not just into the top of the original floor. Acrylic prime the underside & edges of the ply before laying.
There are many things that can catch you out when tiling a suspended timber floor. I would advise you read the Tiling Sticky & Forum Archive posts before doing any more work or buying materials, it could prevent you making disastrous & potentially expensive mistakes. It’s also important to use only quality trade tilling materials of the correct type for your tiles & tile base; cheapo own brand & DIY stuff is mostly crap.
Whoever advised 9mm ply is sufficient has given you poor advice, it’s marginal at best. The BSI & all adhesive manufacturers’ recommendations for ply over boarding is 15mm WBP minimum, however, in most cases 12mm is sufficient. Joist are 16” pitch but, just as important, what size & span are they?
If you use 9mm ply you risk tile failure, you’d be better using a decent 10mm tile backer board but it’s your decision!
