Sealer, primer, or mist coat bare and old plaster?
26 Sep 2018
I've removed 2 layers of wallpapers and a layer of lining paper, it revealed a grey plaster that was originally from the 60s. I have repaired imperfections and cleaned the wall the best ability I can.
I know that bare plaster wall should be mist coated first, but I am not confident the wall is completely adhesive-free as the lining paper was there for 50+ years. Also, there are 2cm of paints near the edge of skirting board, door frame, and ceiling. The paint can't be cleaned off by acetone so it's not water-based.
Can anyone advise how to proceed with painting the wall please. It appears the white paint on wall edges are on all walls in this house. Can I use mist coat in combination with a sealer such as Gardz? ie, mist coat most areas and use Gardz in painted or problem areas?
If you are not certain all the paste has been removed (you can only tell when the wall was wet being washed/scrubbed) then use Gardz. Do not worry about the edges that have oil based paint, if you use a quality trade emulsion it will adhere on the oil paint as long as you don't go testing it with a wet scrubbing pad.
