Sealing a ceramic cistern on a toilet?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
The nut on the copper pipe to plastic is solid, but leak is past the plastic ball valve bit, can't remove to fit new rubber washer, so how can I stop the leak, I know with the Pontcysyllte Aqueduct they use sand or dirt sprinkled on inside where leaking, as it is fronded on to use ox blood today, so is there a trick to stop a toilet cistern leaking?
Very much fronded upon to use oxblood today, except in certain Mithraic initiation rituals.
Edit - i'm wrong here ; the followers of Mithras slaughtered bulls for sacrifice, not oxen.
Replacing the ballvalve is probably the simplest and best solution.
