    Dismiss Notice
Sealing area around pipe
Discussion in 'Plumbing and Central Heating' started by joec_85, 19 Feb 2021.
  1. joec_85
    joec_85
    12 Dec 2010
    23
    Thanks Received:
    Dublin
    Country:
    Ireland
    We have a lean-to which contains a bathroom (I think it was previously an external bathroom but that the lean-to was built around it). We also keep our washing machine in there.
    I was installing a new washing machine drain when I noticed that the waste pipe drops drops down to the drain under the lean-to via a rather large hole in the floor, which I imagine is letting fumes back up (and making my lovely new P trap quite pointless).
    [​IMG]
    [​IMG]
    The gap is about 1-2cm wide, all the way around the pipe and I can see the drain beneath.
    I was just wondering what the best way to fill this might be? I had considered expanding foam but wasn't sure whether it would just fall down into the drain underneath without some kind of support. Will just spraying the areas that I want it to stick to with water be enough?
  2. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,508
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    Foam filler.
    Andy
  3. Sponsored Links
  4. joec_85
    joec_85
    12 Dec 2010
    23
    Thanks Received:
    Dublin
    Country:
    Ireland
    Cheers Andy, do I need to back it with anything first or just spray the pipe with water so that it sticks?
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,508
    Thanks Received:
    1,913
    Hertfordshire
    Country:
    Just foam it up, then cut it flush after 24hrs. (don't use too much, it does grow)
    Andy
  6. Sponsored Links
Loading...
Share This Page
