Sealing Bath Waste
24 Sep 2006
Hampshire
Hi, I am currently refitting our bathroom and have a question regarding the bath waste. the new bath is steel and the bath waste is this one...
ae235
...from Screwfix.
Both the plughole and the overflow parts have a white foam sealing gasket to seal between the chrome part and the bath tub. Should I rely on this foam gasket or should I discard it completely and seal with some silicone instead.
I'm just not too convinced that the foam gasket is adequate.
Any advice gratefully received.
Russell
Lose the foam gasket, and get a good squidge of silicone in there, so it squashes out nicely when the fitting is tightened.
John :)
As per Burnerman
When the waste has bitten down and the silicone squidgies out the side, give a light spray with a degreasant like Mr muscle, finish tightening waste and then wipe around edge with finger on to kitchen towel to get rid of excess.
Stops the silicone making a mess and leaves a clean finish
John :)
Thanks John, that's what I thought but just wanted confirmation.
edit: Thanks terrydoh as well. sorry your post appeared while I was replying.
As terry Says, everything is cr*p these days and its up to the plumber to put it right unfortunately.
Do you also put silicone on the rubber washer that sits on the underneath of the bath and the waste?
I do too, just heard some one mention if you put silicone both sides it can stop the rubber from bitting and it can slide out of precision
Eeerrmm
Slide it back in :P
Once it's set, it's going nowhere
Do get a few calls for leaks under baths where the bath waste isn't siliconed and its worked appart
