Sealing gap
4 Sep 2010
London
Apology if it's the wrong category, not really sure what it fits. Basically the previous owner of this flat did a bodge job on the kitchen leaving us with a rather big and uneven gap between the kitchen worktop and the wall. At the widest it's about 1.5cm.
Any idea/suggestion how to seal this? I'm wary for the dirt and water to go behind the worktop. Pictures are attached, that's a £2 coin next to it, that's the widest gap, the rest are quite small maybe less than 0.5 cm.
I don't think a Polyfill seal will work? It will fall down I'd imagine?
As Angel says, an upstand would work well in this scenario. Have you considered tiling the wall behind the worktop? It could bring it out quite a bit if you used thicker tiles (don't forget to silicone behind that gap though.)
:wink: :wink:
Hello,
If you're not planning on tiling then this sort of thing would cover the gap and provide a seal:
http://www.genesis-aps.com/index.php?page=products&group=56-beading-pvc-
If you are tiling, then put something like this under the bottom row of tiles:
http://www.genesis-aps.com/index.php?page=products&group=45-internal-trim-pvc-
Neither should be more than a few pounds a length, but try to stick with an independent tile shop because the DIY sheds charge way over the odds for them!
Good luck
K
Thanks for the suggestions. Tiling is a major work which I'm not keen of doing :)
That beading looks good, I can't find any such thing on my local homebase though may have to trek out a bit.
You could also ask double glazing suppliers or installers if they have any mouldings that may be suitable. I use various types in bathrooms and kitchens with an anti fungal silicon sealant. Use masking tape to stop the sealant getting all over the place.
Glue with the sealant a piece of something into the gap to provide a good base for the moulding.
