I'm installing plywood flooring onto a concrete/tiled floor as a finished flooring in a bedroom.
What would be a inexpensive way of sealing the plywood to eliminate splintering and protect from moisture? I understand that a good option is Osmo oil however that is far too expensive.
I'll go out on a limb here; is waterproof PVA viable for sealing plywood?
Also, could I fix the plywood using glue directly to the concrete?
Thank you
Thank you
