- Joined
- 22 Oct 2016
- Messages
- 2
- Reaction score
- 0
- Country
Hello, currently just about to lay a concrete slab for our double garage project that will double as an office space. I want to run 3 twin wall ducts from the house to the garage and just want to know the best way of installing these.
Was thinking dig a trench 600mm deep from against the house into where the concrete slab will be laid. I would then knock a brick or 2 out from as low down as possible on the house wall (we have a cellar) and bring the duct straight into the house through this gap. I'd then seal round the ducts with mortar.
At the concrete slab end, is it acceptable to have these run under the slab and come up through the slab so that they are against the wall when the garage is build. Would I then cut these flush with the concrete slab inside the garage with the cables going straight into 25mm pvc conduit. I want this to look a super clean install. How would I fill the 50mm holes where the duct comes into the slab, can these just be filled with mortar or expanding foam, how does the professionals do this aspect.
1 is for a 6mm armoured cable (if i run the duct and take pics as I go will an electrician happily pull his cable through my ducting)
1 is for cat6 cable for CCTV, Computers, Phones & Doorbell coms
The third will be used for an outside tap mdpe pipe, this will come up on the outside wall of the garage. Is it ok to have an outside tap feed come directly from the ground to the tap or should it go into the garage and then come back out the garage.
This is the ducting I plan on using for reference.
http://www.draindepot.co.uk/63mm-x-50m-purple-twinwall-communication-cable-duct.html
