Hello
We recently had an old back boiler and gas fire removed from a fireplace and replaced with a new central heating system.
This has left a big ugly space in the fireplace and I want to seal it up and put an attractive front on it.
What would be the best option for me to seal up the fireplace and tile over the top?
I was originally going to put some wood (hardboard or mdf) into the hole and then plaster/polyfill to a flat surface and to seal any gaps, then tile over the top of that. Is that sensible, or should I be aiming to use bricks and mortar to seal the gap? And then what would I put on top of this to create a surface for tiling?
I have heard hardboard is not a good surface for tiling straight onto.
I have also read that you need to be careful with sealing up fireplaces due to condensation. If that is the case, how do I prevent this from happening whilst still being able to put an attractive facade on the front? Leave some holes?
Any advice would be gratefully appreciated.
Thanks,
Tom
Thanks,
Tom
