Secure front + back door
10 Apr 2013
Yorkshire
Hi any 1 advise what the most secure door is ?
Upvc or wood ?
I presume wood , and what locks are best I have read up about thieves using mole grips and snapping the barrel
Currently gettin all new upvc windows and doors at the same time so would like advise on doors please ?
Any links and pictures please ?
hardwood door, hardwood frame, BS 5-lever mortice lock plus BS deadlocking nightlatch.
neither of these locks will have a Eurocylinder, and the 5-lever cannot be bumped. If you can afford the (formerly Chubb) Union 4L67E nightlatch, that can't be bumped either, and is practically unpickable (not that anyone would try)
If you can afford Ingersoll London Line, you can have a mortice deadlock and a nightlatch suited to the same key, I dont know of anything better.
The back door only needs a mortice sashlock, BS 5 lever, and rack bolts top and bottom.
Any glazing in or around the door, 7mm laminated with glazing tape in the rebate
letterbox preferably not in the door, but to the hinge side, as far from the locks as possible.
Although it will be far better, it might end up no dearer than a plastic door.
