Securing Loft Joists
4 Feb 2007
I wanted to board over the loft area to provide storage in our 1950's house. I need to add extra insulation and wanted to add more joists (at right angles to those there) put in 150mm extra insulation in between then Chipboard over the top. The loft currently has 6" by 2" wood binders down the length of the loft which make boarding out really awkward. So I thought could I replace these with metal straps running alongside and then cut out the wood binder. So the question is are the metal straps going to be sufficient support in place of the wood binder?
Not really unless you were to install timber noggins between the existing joists at the strap positions also. Is there a particular reason you want to add joists above the existing ones running the other way ?
Well I wanted to add more insulation over the existing 100mm but this current insulation is level with the existing joists and therefore I thought to add more I needed to add more joists so that I could then board over that. The reason I wanted to remove the existing binders is that they are awkwardly placed and therefore I don't get much space for boarding over.
Thanks for you advice
There probably wouldn't be a problem with running the additional joists that way although just be aware that it will not make the floor any stronger and you could argue that it makes it a bit weaker because it has to carry the extra joist weight.
An alternative would be to install deeper joists parallel with the existing if you can get them in ok and onto the walls, which would then strengthen the floor also, possibly to a standard suitable for a loft conversion in the future.
