Securing substitute lead on abutments
27 May 2026
Hi, after having my roof abutments 'professionally' patched up a couple of times only to find bits of mortar raining down on my car I eventually bought the gear and went up there myself and covered them in a lead substitute. This has been great for a few years but it's now lifting badly at the gable end with the wind. I originally stuck them down with Ubiflex High Tack adhesive and some big bolt head screws, I'm now thinking I need to screw fix a strip of flat bar down the edge so it can't lift.
Any recommendations on what metal type (if metal at all) would be greatly appreciated. I had thought anodised Aluminium as galvanised steel will maybe eventually rust??
Note the pic is pre-lifting problem.
Also any ideas on a cheaper alternative to the Ubiflex high tack adhesive?
Cheers
I would consider that as a temp fix only.
But if you're happy to live with it for a few years, you could get a large washer (8mm x 50 penny washer) under the bolt heads to stop the vegan lead from pulling out.
Ali strip would work too.
Cheers for the reply man, those were bolt head screws with a washer baked in under the bolt head, granted not 50mm but they still didn't hold it long. I think a strip has more chance of stopping it, just with me not being in the trade I didn't know if it was the done thing or whether a roofer would look at it and think who's bodged this!
If you don't mind me asking why would you say this is a temp fix only? Is it because I didn't use real lead? Just I think this stuff is supposed to last up to 30 years.
The issue I had is that I was paying roofers hundreds to go up and re-render parts or the lot of it, one time I had chunks raining down after a couple of years and then then next time sand, so I'm guessing the render mix wasn't right. Though this is fake lead it seems like a far better solution if I can stop the wind lifting it, it's adhered to the tile side perfectly.
The problem is it's the same on the other side but with the chimney stack on top so I could have only done that on the gable side. Plus I can imagine that being labour intensive, i.e a similar price to paying to get it covered in real lead by a pro.
