securit 700l alarm panel
10 Dec 2006
Sheffield
Hi can anyone tell me the procedure to return my securit 700l alarm back to default user codes i have tried putting the link on the pcb for defaults and then powering up but its not altering it and i do not get an accept tone from the panel,also the battery is dead would this effect it.
thanks.
.... also the battery is dead would this effect it. thanks.
Oh yes, a 'duff' battery will make any panel do funny things, or, nothing at all.
I'm afraid I don't know your panel so I can't confirm or not whether you are doing it correctly or not.
Why do you need to Default the codes?
Can't you just change what you have with this panel?
Hi europlex
the panel is a replacement i bought off ebay ,the chap i bought it from says he doesn't know the origanal codes so i need to default the panel.i will try a new battery and see what happens thanks.
So you have a 2nd hand panel, with no codes that is at the best description "tat"
No longer made, or supported by the makers.
Haahahahahahahhahahaaa
Have a word with yourself.
hey alarm why reply if your not going to help ,im not working so cant afford a new one or someone to look at it.
I`ll rephrase my answer.
Your system is no longer supported.
What you have asked is covered many times in/on this and other forums. You could have searched rather than ask. The answer being the same.
Your panel if as you say does not respond, what do you want "us" to do?
Wave a magic wand?
It is old, no longer supported and broken.
Harsh?
Tough, its a fact!
hi what you are doing sounds correct are you definatley shorting the correct link as there are two sets one for tamper and one for the nvm reset also are you sure its a 700l pcb ? how many lights on your keypad? worst case get in touch as i think i have a spare kicking around if that does not work. thanks mark
sparkymarka i have taken the transformer out of the old panel and put it in the replacement ,then did the procedure to default the panel and eureka its worked don't know why but it worked i only changed the transformer because it was buzzing thanks for your help and advice .
also thanks Europlex.
