hi.
i wanted to put up a security light with attached PIR at 500W, i wanted to do this via a 3amp (3pin plug) 3 core 1.5mm core cable directly from the light into the 3pin plug socket, as i dont want to take a spur. to much messing drilling etc.
is this okay? 3 amp fuse and 3 core 1.5mm black wire???earth to earth, blue to blue, brown to brown??
black core 1.5mm okay for outdoor use? as the cable will be coming from the outside wall into the socket (inside)??? is this cable okay for wet weather???
plan is where i will drill hte hole on the putside to hang the light, the socket is located (3 pin plug) close to the hole. so its a matter of feeding the cable through the cavity wall and plug straight into a 3 pin...so all in all 1 meter 1.5mm cre black cable needed..
