It seems I can't dig deep enough for the front gate I want to build. I've been told I should have 1/3 of my fencepost underground, I've hit some roadblocks, and am not sure which way to go.
The holes: I've dug each down 2'1". In one hole, I've hit a large rock I can't get past. I'm pretty well at my limit due to arm length anyhow. I've not had much luck with the digging scoop, as the soil at that depth is sand and rocks, and just falls through the hold in the scoop. Power tools are out as my locate says I'm digging close to power. I've pretty well accepted that these holes are as deep as their gonna get, unless someone has any other ideas.
The posts: I want to have a 6'6" clearance, and on top of that a 6" Arbor, which I believe should give the frame some support. This doesn't seem doable given the shallowness of my holes. I've already bough 4x6x10' posts for this.
Can I get away with sticking my posts in these holes, or is this completely stupid? Is there something else I can do to make this work, or should I change my plans and just go for 4 foot aboveground posts for the gate, and forget the arbor?
Thank you in advance,
Sandy.
Sandy.
