    Dismiss Notice
Seems a bit exaggerated.
Discussion in 'Home Automation' started by GreenCat, 20 Aug 2015.
  1. GreenCat
    GreenCat
    10 Dec 2008
    163
    Thanks Received:
    35
    Lancashire
    Country:
  2. Sponsored Links
  3. SimonH2
    SimonH2
    4 Nov 2010
    5,846
    Thanks Received:
    596
    Cumbria
    Country:
    Seems ? No "seems" about it - it's complete bol...rubbish.
    There is no compatibility issue - more likely a load of so called engineers in "all the gear, no idea" mode.
  4. GreenCat
    GreenCat
    10 Dec 2008
    163
    Thanks Received:
    35
    Lancashire
    Country:
    Yup, that's what we thought since we've installed both together and had fewer problems than with the Tado system.
  5. Skyhigh
    Skyhigh
    28 Mar 2011
    87
    Thanks Received:
    2
    Yorkshire
    Country:
    Few quick observations:
    1 - He went with the NPower deal, which cost £450 more than the "no free Nest" option. So you ended up paying £450 for a £200-£250 device. This doesn't reflect well on him tbh.
    2 - It refers to Nest failing to control his hot water. Nest does not control hot water in the UK, only heating. Only Tado and Hive do heating & HW. So, that's simply wrong. With Nest you have to keep your standard controller/timer for HW management.
    (I researched these devices a lot before going with a Tado [self install] but work with plenty of people who use Nest/Hive and other smart systems).
  6. big-all
    big-all
    12 Jul 2004
    18,982
    Thanks Received:
    1,491
    Surrey
    Country:
    my thoughts where the fuel would be far more expensive to pay for it
  7. DrJimFranklin
    DrJimFranklin
    27 Aug 2015
    60
    Thanks Received:
    4
    Swindonia
    Country:
    Far better and easier ways of achieving the same..as for the article...load of *******s. It's not NPower (British gas) but my other half has a Nest that controls her Vaillant boiler and has not issues at all.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
