I removed the lounge radiator to decorate. Once the feed pipes had stopped gurgling and slurping out the majority of the water I put a large blob of blu tak over each. This maybe stupid (in hindsight) but I've done it plenty of other times!
Anyway, a piece of the blu tak has dropped into the pipe and the radiator (although full of water and bled) is now cold.
I know where it is, I can feel the pipe going from hot to cold, and when I open the bleed valve the blockage travels as the pressure escapes. But when the bleed valve is closed, it subsides to under the rad again.
What's the quickest and easist way to flush this blockage out?
Thanks in advance.
Chris
Thanks in advance.
Chris
