    Dismiss Notice
Self levelling compound maths check
Discussion in 'In the Garden' started by Hagus72, 13 Aug 2021.
  1. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Hi all
    Apologies if this is in the wrong forum. I am going to attempt to level my shed floor. It's a combination of tarmac and concrete flags. All in good condition but just looks odd. The area is 3 metres squared. I am thinking of using mapei 3240 for this job which says it covers 6 square meters at 3mm. Therfore in my head I would get 6mm spread out of one bag? However I want to raise the floor a little also...... Maybe an inch all round. There is a slight dip in the middle of about half an inch so I am thinking if i chuck 4 bags at it that would get me 24mm all round in a perfect world.... Take into account the dips and I might end up with say maybe 20mm all round which would be fine. For info the floor is pretty level side to side and back to front. Any advice would be appreciated
  2. Sponsored Links
  3. mikeey84
    mikeey84
    7 Jan 2011
    1,237
    Thanks Received:
    139
    Warwickshire
    Country:
    Sounds about right, but depending on the size of the dip, you may not get 20mm total.
    You'll want a helper so you can mix and pour as quickly as possible
    • Like Like x 1
  4. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Thanks Mike.
    Yes I suppose mixing 4 bags in one go might get a bit heavy lol
    Do you have to mess with it much once it is poured? Or just leave it to do its thing?
  5. conny
    conny
    30 Jun 2008
    14,135
    Thanks Received:
    802
    Suffolk
    Country:
    Do you mean 3 square metres, (i.e. 1.73 m x 1.73m), or 3 metres squared, (i.e. 3m x 3m), which will actually be 9 square metres.
  6. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Hmm good point. It is 3 metres wide by 3 metres long..... So whatever that is :D
  7. conny
    conny
    30 Jun 2008
    14,135
    Thanks Received:
    802
    Suffolk
    Country:
    That will be 9 square metres and throws your calculations way out of kilter.
  8. Sponsored Links
  9. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Thanks Conny..... Yes I am going to need alot more bags :eek:
  10. magicmushroom666
    magicmushroom666
    11 Jan 2010
    306
    Thanks Received:
    59
    Essex
    Country:
    I managed to do 6 X 4 M on my own, that was mixing in a dustbin with a paddle mixer and a lot of stress but its possible! Had buckets of water all measured out etc so could go straight into the next mix.
    It doesn't really completely self level itself, you need to push it around with something to even it out, otherwise you'll just end up with a high spot where you pour it. I added some wooden flat sections to a garden rake to make a kind of squeegee which worked well.
    Only regret is not getting a spiked roller, air bubbles ruined the finish somewhat.
  11. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Thanks magic. What were you covering? Also was it out of level much?
    Did you use many bags?
  12. magicmushroom666
    magicmushroom666
    11 Jan 2010
    306
    Thanks Received:
    59
    Essex
    Country:
    Was covering a rough tamped concrete base, which was pretty level, just not very flat and a few dips in places. Sorry I can't remember how many bags, but I bought more than needed and returned the left over!
    • Like Like x 1
  13. Hagus72
    Hagus72
    6 Jul 2021
    16
    Thanks Received:
    Country:
    Cheers magic.
    You have all been very helpful (y)
    • Like Like x 1
Loading...
Share This Page
