Hello all. I am planning to lay engineered floor in our bedroom but I need to prepare the existing sub-floor first. This is an old victorian house and existing floor is made of old pine floor-boards, which seem in good shape from a structural pov but does need flattening/leveling in places. My idea right now is to overboard the whole thing with 9 or 12mm plywood (glued and screwed) and level the low spots with self-levelling compound.
The question that I have is that it is only some parts of the floor that need levelling, especially a large-ish circular dip in the middle of the room of about 10mm depth at its deepest. Is it ok to just pour SLC in these low areas and feather out the edges? I will be gluing the engineered wood on top of this. Is this acceptable practice (gluing the final covering over a patch of SLC)?
Another idea that I had was to use caulk to block all joints between floorboards and pour the SLC directly over the floorboards and then overboard with plywood to then glue the final layer on top. In this case I would screw the plywood through the SLC.
What do you guys recommend?
Thanks.
Jacob
Thanks.
Jacob
