Semi-split pipe insulation (or non-split)?
19 Feb 2015
If installing new internal copper piping then it would be possible to simply slide non-split insulation over it before installing and soldering.
However, perhaps soldering an already insulated copper pipe is a possible fire hazard, therefore meaning that semi-split insulation should be added after the piping has been installed and soldered?
Was wondering what comments were on whether to use non-split or semi-split insulation? Thanks!
Yes, but leave about 18 inches ( for 15mm pipe ) un-insulated at the ends where you will be soldering. Then, when soldered and cooled, fit split insulation onto the soldered joints.
