- Joined
- 9 Dec 2008
- Messages
- 34
- Reaction score
- 0
- Country
Hi All,
Can you let me know if im OK in doing this? Im about to add Sentinel X400 to my heating system due to a sludge issue.
I then intend to leave it for 4 weeks before turning off the boiler then opening the bleed valve in my top most radiator and opening the pressure release valve outside my house from the back of the boiler to empty the system.
Refill with water then flush immediately again for good measure (no Sentinel X400).
I then want to add a protecting fluid and get a local plumber to install a magnaclean at this point.
So does that sound about right? Will sludge moving toward the boiler be a bad thing as it empties? Should i install the Magnaclean at the same time as I add the X400? And roughly how much would i be expected to be charged just to install a Maganclean assuming i buy one?
