Whilst clearing rubble and rubbish above my septic tank I have found a broken off 100mm pvc pipe stub which I asume was a vent into the septic tank. Is this what it is? The drainage from the tank appears to be solely by percolation through the tank walls according to the CCTV guy who did a survey for me.
The drainage system from the house includes a SVP which itself comes from the nearest manhole which is about 10m above the tank inlet on a steeply terraced site and rises another 3 floors above that to the house roof. Also included recently are 3 new drain branches which all terminate in an AAV located inside the property.
We've not had any problems with smells, yet, due to not fully using the system whilst renovating and converting the property. Do I need to reinstate the tank vent, if that's what it is, and does it need an AAV type of termination or similar in a safe position?
I've looked at various Klargester tank drawings online but although a vent is identified it gives no details which I could follow.
Any help much appreciated.
Edit: The new drains have all been approved by the BCO but no comment has ever been made about the septic tank. I assume this is because it is existing and privately owned.
