I'm trying to sort-out a problem with a friends Servowarm boiler.
Here are the symptoms:-
After running for a while, the boiler stops completely - the burner is off, and so is the pilot light.
If I wait a while, the boiler can be reset and started again and it runs fine for a while, then it stops again (inc. pilot light).
I've checked that the pump is running fine and that the strange diverter valve does actually divert, so all's fine there.
To me, the issue seems simple:- the burner is not being shut-off when it should. Instead the emergency fail-safe device is cutting the gas supply.
Before I got to see the boiler, a professional plumber had been called-in and he diagnosed a failed diverter valve and a failing pump. I was unable to understand this diagnosis.
Anyway, the help I need is to identify the component I need to replace (I presume it's the little plastic box with the boiler temperature setting knob on it, as the thermo couple coils/pipes go in to it). I presume it could also be a failed thermocouple. How do I determine if the thermocouple needs replacing?
One more problem is that the pump is continually running (24/7), even when the timer has turned off the boiler. Is this normal.
I'm definitely a DIYer, so any help with part numbers and suppliers would be very gratefully received.
Thanks,
Mark
Thanks,
Mark
