Several leaking radiators after new boiler installed
3 Jul 2006
Had a new boiler installed about five weeks ago. A few days ago had a leak from one radiator valve which despite taking the valve off, giving it several PTFE wraps, is still leaking. Had a quick check on all the other rads and found three more also leaking. Tried tightening them up, but they are as tight as they will go and still they leak. Boiler pressure is 1.2 bar so not. Over pressurised.
Could it be related to chemicals used in flushing the pipes? Should I drain and refill the system?
Any other suggestions?
Just to clarify, it's not the rads leaking, it's the valves most of which are relatively new.
Did your boiler replacement involve converting from an open vented system to a pressurised one? If so, that could be the cause of the leaks.
If the leaks are coming from compression joints rather than the valves themselves then the only real option is to remake the joints with new olives.
If the leaks are coming from the valve spindles, you could try tightening the gland nuts a bit, but the long term answer is just to replace the valves.
It was straight swap ageing Vaillant combi to a Worcester combi.
From the valve spindles, the valve to pipe joint, or the valve to radiator joint?
One is from the radiator tail. Bit strange as it only leaks at night when heating is off. Perfectly ok when heat is on. I guess contraction and expansion is causing this. Planning to replace the tail or the complete valve. If this doesn't work then it's a new radiator.
The other two appear to have leaking for some time as there's rusty water around the gland. Both of these are Honeywell evohome thermostatic valves which cover the gland nut so not easy to see when assembled. I've tightened the gland nut slightly. If this doesn't work I'll replace the valves.
