I am at my wits end with this because i cant figure out where its coming from.We have had a number of jobs done on the wall where the window is situated including replacing the window itself ,because of a constant issue with damp penetrating from the a outside ,The wall itself is brick double skinned with a cavity which has been filled with insulating polystyrene beads although the damp issue was there well before they were put in.
The outer skin of the wall has been painted which doesn't seem to act a s barrier to driving rain.
When we first moved into the house we had the areas around three windows on the wall replastered because it was literally falling off.We also had the trays over the windows replaced and new weep holes installed.Now that has worked for two windows but not the other.Any holes or gaps that we could find in the brickwork we had filled in and checked the guttering to see if that was blocked and it wasn't.
Had two building surveyors round who could not enlighten me the builder I used has obviously not cured the problem so i really don't know where to turn to.Another builder, structural engineer or damp proof consultant? Can anyone suggest what I can do? Thanks
