I have a modified rear wheel drive Ford Escort MK2 and it has severe scuttle shake whenever I lift off the throttle while still in gear.
Typical scenario:
I am accelerating down the road to say 60 mph, lets say in 5th gear although it could be any gear, and all is fine
Car pulls well, no shaking, no noises, no clonking
As I am catching traffic up ahead I lift off the throttle, still in 5th gear, to slowly close the gap ... and the scuttle shake begins
The shake feels like it's coming from the front, the engine, but that could just be where the noise is appearing and not what's causing it
Remember this is a rear wheel drive car with the engine in traditional direction, ie not transverse.
It has done this since I bought it but due to the number of times it gets used a year I have ignored it, but I'd like to cure the problem as it makes long distance driving a pain.
I had a gearbox guy look at it and we brainstormed what it could be and eliminated what it couldn't be :
It isn't the engine missing, as it never misses on tick over, on acceleration or when cruising
It isn't the clutch (it has a race drive plate with no springs) as once its in gear (and the clutch does not slip) then the clutch is basically not being used and just passing the energy through to the gearbox input shaft
It isn't the gearbox as it happens in all gears, and when in top gear it's straight through anyway
1) It could be weak engine mounts but they look ok although hard to tell unless tested with a pry bar
2) It could be the crossmember that the engine mounts are connected to but that would mean its very loosely fastened to the chassis and rocking
3) It could be the propshaft Universal joint (there's only 1, the other end being splined) but from years of numerous Spitfire ownerships they clonk on drive take up as well as power off and unless really gone when they rattle/vibrate just before they fall to bits. There is no centre propshaft joint it's 1 piece
4) It could be play / lash in the Diff
5) It could be the rear axle mounts
6) It could be the rear gearbox mount
The gearbox guy defined it as "it's when you lift off the throttle, it's as though the rear of the car is pushing the front, instead of vice-versa, like on over-run, and it's fighting against the engine as the engine revs drop"
If I press the clutch in when off the throttle, there is No scuttle shake -presumably as the rear is no-longer fighting a slowing down engine
Anyone had this before on a longitudinal RWD setup ? This isn't a standard Escort MK2, its a highly modified Turbo road car with lots of non-standard parts.
Any ideas what it could be and how I can eliminate each of the possibilities to narrow it down would be most appreciated.
thanks
Typical scenario:
thanks
