Do you work for SP or should i say EN, or should i say IBERDROLA........securespark, I install the switchgear with SF6 in it, and what flameport says is bang on, its not dangerous in the quantities used in the switchgear. thats what the men in the know tell us anyway.......However when the switchgear has exploded it creates a nice white powder that is apparently an acid that seeks calcium (bones), so when the powder gets wet and onto the skin, it can be very nasty indeed....
The most basic knowledge of chemistry (let alone the odd a level and degree) says that is not possible - the acid is only "seeking" an alkali / water - it's an acid after all...
seeks is probablly not the right word for it but HF (hydroflouric acid) can seep through skin causing little to no initial pain and then attack the bones underneath.
