shallow depth K2 radiators?
7 Oct 2022
Hello All
I am wanting to upgrade my hallway radiator to a K2. 600 x 1600. Because of the front door, I am limited to 100mm deep including the brackets. Does such a rad exist? (I cant really go longer with a K1).
Thanks in advance for any help.
RG
Radiator brackets often allow two distances from wall to radiator lug fixing... Stelrad softline are 17mm or 31mm depending on how bracket affixed to wall... Stelrad P+ would be 102mm from wall (K2 125mm), according to my 2017 copy of the brochure pages.
P+ would be 2152W cf 1658W K1 and 2771W K2 (delta 50 T) or 1108W / 808 W / 1427 W (delta 30).
EDIT K1s can go to 700mm high x 1600 but won't give much extra 1787W (50) 920W (30) output. Other makes may do taller still?
Thanks for your reply. I need 614 watts at a flow temp of 40C. I will have to do some calculations and find out the correction factor etc.
I don't really want to go higher than 600 as there is a dado rail. 125 wide is certainly too wide. I think I saw a designer K2 rad somewhere that wasn't too deep but it was really expensive and I cant find it again. I will keep looking.
It may be that I have to add another radiator somewhere else as well but space is tight in the hallway. I know about the distances but it is still bit too wide even with the narrowest fixing. I had a quick look at the P+ mentioned above maybe this is a possibility . I'll find out the deltaT at 40 and see. Thanks again.
A while ago when I was looking at designer rads they were style over substance and did not give out as much heat as a standard. I would be taking off that section out dado if that is what is stopping you going taller. I think output on paper may not translate to feeling warmer in real life espicually if you only increase the W by a small amount.
Maybe I will have to cut the dado (will have to check with her highness). This is early stages at the moment. Ultimately, I want to be in a position to get a heat pump when the time comes. The boiler still should have ten years of life in it. I was experimenting with low flow temps last winter. I will still have a hunt around for suitable rad's. The hallway is the only problem radiator. Normal K2s will be alright elsewhere in the house.
614 Watts at delta T 20C (40 flow, 20 Room - halls don't need to be hot ;) ).
Stelrad can probably provide numbers if you ask them nicely? https://www.stelrad.com/news-events/blog/the-importance-of-delta-t-in-calculating-heating-output/
https://www.radiatorsdirect.co.uk/delta-t-conversion has a delta T converter from 50 to an other tool / calculator.
That 600x1600 Stelrad K1 would be 498 Watts at 20. The same size P+ would be 646 Watts. So if 102 mm depth suits you have your solution with a bit to spare!
EDIT FWIW the tool gave the P+ 1098W at delta 30 cf my Stelrad brochure's 1108W (a 10 Watts difference, less than 1% error).
https://www.radiatorsdirect.co.uk/delta-t-conversion speed stars online has a delta T converter from 50 to an other tool / calculator.
At 20 watts, that 600x1600 Stelrad K1 would produce 498 watts. 646 Watts would be the same size P+. Thus, you have your answer with some extra if 102 mm depth works for you!
