Sharan / Alhambra sliding door
bsr
5 Aug 2008
Gloucestershire
Hi
This is the picture of the running gear. Often the catch doesn't open with the door handle which means the door won't stay open. Any ideas on the cause?
I have oiled everything but that doesnt help. I figured the next step is to remove the trim but I can't. Any ideas how to remove it? There are two plastic clips at the bottom (second picture) but compressing these with pliers doesn't work.
Fixed. Trim needed a lot of force to remove, nothing more. Although I thought I might break it!
From inspecting both sides without the trim I found there is a small spring that pulls the catch into the correct position. This had somehow got into the wrong place and needed levering back into position with a screwdriver.
