shared water suply pipe
30 Apr 2012
Lanarkshire
Our shared water supply pipe is quite old and comes off the water main at the junction and travels up our private road/track to each house. There are 6 dwellings on the road. The pipe then goes across a field, rising vertically by 80 feet to another 2 dwellings. The pipe is about 2" in diameter and the static pressure is 4 bar (max). The total length of the pipe is 800m. Those at the end of the pipe get 2 bar and the working pressure is quite poor as you can imagine. What would we need to do to get the pressure up and how close to 4 bar would it get if we did an upgrade of the pipe? How much would it cost? Can we hire equipment and do it ourself.
Lots of calculations and unknowns. If it was me I would be liaising with your local water board, before starting anything, as they will have figures relating to the mains pressures and even plans of the existing mains supply. :D
Whatever the static pressure at the supply end, a rise of 80 feet will reduce the static pressure at the top end by about 2.5 Bar, no matter what happens in between.
