    Dismiss Notice
Shaver Socket in Bathroom on Lighting Socket
Discussion in 'Electrics UK' started by neljan, 11 Jan 2020.
  1. neljan
    neljan
    2 Jun 2014
    26
    Thanks Received:
    London
    Country:
    Hello
    I currently have a shaving light with a 240v shaver socket built into it which is connected to a lighting circuit.
    I would like to know if it is possible to remove the light and just fit a dual 110v/240v socket to the existing wiring and if so, is there any particular kind I need to get?
    Thanks in advance.
  2. Sponsored Links
  3. AndyPRK
    AndyPRK
    4 Jan 2009
    5,401
    Thanks Received:
    515
    Herefordshire
    Country:
  4. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
    But don't get the MK one linked to. The 115v socket on the MK ones won't take a UK shaver plug. Why does this matter? Because regulation on such shaver outlets is poor meaning the the 240v outlet rises to 280v on low load such as when charging a toothbrush which could damage it. Toothbrush chargers are generally rated at 100-240v and are best (most safely) charged in the 115v outlet which gives around 140v on low load.
  5. neljan
    neljan
    2 Jun 2014
    26
    Thanks Received:
    London
    Country:
  6. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,449
    Thanks Received:
    3,968
    Retired to:
    Country:
    Portugal
    You must have one to BS61558-2-5.
    It looks like it is but it does not actually say so.
    It doesn't say, therefore it is not suitable for toothbrushes if that is a consideration.
  7. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
  8. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
    Can't see why any one won't work with toothbrushes. They are a small load like shavers.
  9. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,449
    Thanks Received:
    3,968
    Retired to:
    Country:
    Portugal
  10. Sponsored Links
  11. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
    What is your point?
  12. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,449
    Thanks Received:
    3,968
    Retired to:
    Country:
    Portugal
  13. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
    Still can't see your point.
    This is absolutely true:
    "Because regulation on such shaver outlets is poor meaning the the 240v outlet rises to 280v on low load such as when charging a toothbrush which could damage it. Toothbrush chargers are generally rated at 100-240v and are best (most safely) charged in the 115v outlet which gives around 140v on low load."
    I'll add the same applies to rechargeable shavers.
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,449
    Thanks Received:
    3,968
    Retired to:
    Country:
    Portugal
    ..but then you said:
  15. AndyPRK
    AndyPRK
    4 Jan 2009
    5,401
    Thanks Received:
    515
    Herefordshire
    Country:
    How can regulation be really bad?
    They are just transformers.
    Obviously it depends on the supply voltage.
  16. JohnW2
    JohnW2
    28 Jan 2011
    46,222
    Thanks Received:
    2,974
    Buckinghamshire
    Country:
    They are presumably transformers with fairly high internal resistance/impedance, designed to deliver the 'advertised' voltage when connected to the sort of loads they are designed to supply (i.e. mains-powered shavers). When not loaded, or when having a load much smaller than the 'design load', they are therefore likely to have an appreciably greater than 'advertised' voltage output.
    Kind Regards, John
  17. winston1
    winston1
    11 Jan 2010
    6,396
    Thanks Received:
    493
    London
    Country:
    Thankyou John. This has come up several times and some while ago i posted photos of a voltmeter plugged into a shaver socket showing the low load voltages.
Loading...
Share This Page
