Thats where I connected the armoured cable in my outhouse to the consumer unit. An electrician was present to view this much in my plan before I did any of it
No. when I flick the downstairs sockets off on the main house consumer unit, the power to the shed is killed. Its definitely wired into the main house consumer unit
I am getting really confused here.
You have a cable coming out of the house consumer unit into an FCU. That is the one with the neon in the pic with the trunking and the labels.. is that correct?
From the FCU there is a bit of T&E that goes into the wall. Does that connect to the SWA in the black outside box?
The SWA then goes to the shed where it is horribly connected to the shed fuse board.
So where does the switch with the neon img1773 come in to play????
I'm sorry, but I can't believe no one has said this yet..
But based on your lack of knowledge I honestly believe it is best you get an electrician to sort this lot out for you.
