Not sure if this is in the right forum, but:
I have built the framework for the base of a shed and want to put some treated t&g over it. Are there any tips for putting it down? I know it should be staggered, but that's about it.
- what kind of nails should I use?
- do I need to have the t&g parts tightly fitted? or should I leave a slight gap for expansion? if so how to I get the gap to be even? if I stick a match in, do I then pull it out afterwards?
Also,
I have a load of 25mm polystyrene that I was thinking of putting down before I borded on top. what's the best way to put it down?
my frame looks like it is full of small rectangle gaps (imagine the long lengths of wood, with cross-braces going the opposite way) should I cut the polystyrene to fit the entire rectangle, or leave a gap somewhere?
How much space should there be between the flooring and the polystyrene?
any advice would be greatly appreciated.
h
Also,
