Since moving in to my house, I had wondered how they got power to the shed which is sited 20m from the house. This weekend I found that there is a 40mm waste pipe buried just below the concrete slab path. In the pipe there is a bit of 2.5mm2 T+E and a couple of nylon pull strings. The entire length of the external cable run is covered by concrete path slabs (2' x 3').
In the shed there is a power socket and a light. As far as I can see the feed comes from a junction box in the downstairs ring in the house which is connected to the RCD side of the CU. I have not found the junction box yet.
Am I ok to continue using this power feed?
Should I look to replacing the cable in the pipe?
If I make any changes I am aware of Part P. Whold I be OK to use this old pipe for new cable or would I need to dig it deeper?
Thanks for any advice.
