I'm looking to build a shelf to support a heavy washing machine, its 60kg or thereabouts, and and the shelf will be 90cm wide and 90cm deep, supported on brick walls. Will 18mm plywood be sufficient, mounted on top of 2x2 battens screwed into the wall, or should I go for 20mm+?
