Having had our first decent rainfall for ages, I've noticed that there are areas where water has ingressed the new shiplap that I've put on a workshop build..
To recap how it was put up:
Vac treated 'redwood' shiplap was left for 5 days before using it.
So far 4 coats of tung oil have been applied as recommended here.
corners were silicon sealed and then corner pieces build over the joins.
Water is ingressing at the corners, but also in certain horizontal stretches.
I was advised by the wood suppliers not to put felt behind the shiplap, as if water did get through it would be 'trapped' and cause quicker rotting.
I have noticed from the inside that the shiplap does develop gaps of approx 1mm dependant on temperature/humidity.
I am planning to put insulation and OSB3 on the interior walls to make it easier to put up shelves/storage wherever I want, but obviously need to find out what I may have done wrong before I can proceed further.
I have put up some photos Here to give an idea of some of the areas where water is getting in. (shed20 - shed23)
Any ideas gratefully appreciated, as I want to be able to get on with the interior.
Cheers
Cheers
