Shock arrestor question.
27 Feb 2017
Essexshire
Now I have my leak/vibration problem sorted (had the Main Street box replaced), I’m now getting a 'bang' when either the upstairs wc system fills and shuts off suddenly, or I shut off the 1/4 turn cold tap in the kitchen quickly. Pretty sure it’s to do with our water mains being replaced and the pressure is just over 4 bar. The water board employee measured it a few weeks ago and told me the pressure. I was thinking of fitting shock arrestors to the feed to both those lines. Is tgat the right thing to do and if so, would these parts be okay? https://www.unventedcomponentseurop...MIxZr6mdXplgMVJ6NQBh1HkACeEAQYBiABEgIlDfD_BwE
If not, any suggestions of what make to use?
Can you jist turn the stop cock down a little first and see if that has an affect.
Now I have my leak/vibration problem sorted (had the Main Street box replaced), I’m now getting a 'bang' when either the upstairs wc system fills and shuts off suddenly, or I shut off the 1/4 turn cold tap in the kitchen quickly. Pretty sure it’s to do with our water mains being replaced and the pressure is just over 4 bar. The water board employee measured it a few weeks ago and told me the pressure. I was thinking of fitting shock arrestors to the feed to both those lines. Is tgat the right thing to do and if so, would these parts be okay? https://www.unventedcomponentseurope.com/2-x-0-16-litre-shock-arrestor-potable-mini-expansion-vessel-15mm-tee-twin-pack.html/?utm_source=Google Shopping&utm_campaign=Copy Unvented Components Europe&utm_medium=cpc&utm_term=adtribes&gad_source=1&gad_campaignid=17178278874&gbraid=0AAAAADCTOYCQijEm3sGj-dL6j18uCSitx&gclid=EAIaIQobChMIxZr6mdXplgMVJ6NQBh1HkACeEAQYBiABEgIlDfD_BwE
yeah they look cheap enough. BES.co.uk have some too, dearer.
Check if you have any taps anywhere which rarely get used. They can have a bubble of air behind them which can cause a bounce. Just open them to clear.
Banging pipework often gets better by itself. Air dissolving in the water at a high point, maybe.
Another question. Can I fit a shock arrestor anywhere on the cold water main to absorb the shock when a tap is switched off?
Get a drop tight pressure reducing valve (PRV) with a gauge onto the mains - set it to around 3 bar to start with and adjust as necessary until the knock disappears.
Using arrestors only masks the problem ... The problem needs to be corrected, not hidden IMO.
