short wires
7 Jan 2016
Hi, new to the forum and can't seem to see an answer to this one! I am replacing a double socket in the kitchen and the wires are too short behind it to fit the new socket. I have two live, two neutral and two earth. Two questions please; can i extend the wires by joining them in a terminal block? and if so, can i run the two sets of each cables into one block and then a single wire out to the socket to save space? (I hope this is clear!)
Thanks in anticipation! Rob
sorry, thought this was the right forum, couldn't see an electrics one!
But thanks a bunch EFL
It would depend on how short the cables are and whether they actually enter the enclosure within the sheath of the conductors.
If the cables do enter the backbox sheathed or contained if in singles, then you can do as you have asked.
But do use connectors that are suitably rated for the circuit.
If you're just replacing an existing socket, how can the wires possibly be too short? What's changed?
It is quite common for the conductors not to be long enough to reach the terminals of a new socket, as mentioned terminals are not always locate inthe same position on sockets and back in the day, very few sparks gave you any room for scope for alteration.
No, true. but the cables only need to be 5mm short to make them 'too short'.
And as PrenticeBoy has just mentioned, it used to be the done thing to dress the cables short AF. I changed a socket front recently where the cables were entering the top of the box, and weren't even long enough to reach the bottom of the box. That was a fun one!
I find the short-sighteness of so many past (and present!) tradesmen baffling.
