I had an extension socket hanging off a switched wall socket. I turned off the switch and was manipulating the wires in the extension. In the process I managed to trip the circuit breaker. I am pretty sure the wires were not live, although not sure. Is it possible to trip the circuit breaker shorting neutral to earth, assuming the wall socket is single pole switched that did not isolate the neutral wire? I have not checked to see if the wall socket is correctly wired because it's in a hard to access place.
