Hello everybody,
I have recently bought a Victorian 3 bed (+ loft conv) house and have just started investigations in to the plumbing.
Here is the set up:
- Lead pipe supply from mains.
- The main supply T's off: 1 branch heads straight up to the loft conv to a small plastic tank (looks more like a plastic container you buy from tesco for storing junk!) and immersion.
- That immersion then feeds hot to the loft en suite and hot to the 1st floor bathroom directly below the loft en suite.
- Another branch from the main supply heads straight to an outside loo that is no longer in use.
- The 3rd branch then heads to the kitchen to feed the sink. This T's off and heads to the (crap Ideal) combi (located in dining room next to kitchen) which then comes back out to feed the hot in the kitchen only.
My dilemma(s):
1. The loft conversion (done is 1995) is a mess and a miracle that it passed regs. Therefore I would like to remove the immersion and plastic tank in preparation to redesign the loft in 12 months time (I will not be using the room or en suite up there for 12 months). Remember, this immersion feeds the hot in the main bathroom. (plan in 12 months is to have a megaflow work alongside the combi).
2. The mains pressure is dreadful. Next door seem happy with their pressure but I haven't been round to compare.
3. The Lead (which I'm not too precious about to be honest).
If I had a replumb, I could:
1. disconnect the branch that supplies the outside loo.
2. run a new branch to feed the combi directly (rather than the existing one which runs to the kitchen sink first then back to the combi)
3. use the hot supply coming out of the combi to feed the first floor bathroom (rather than the immersion in the loft).
4. Could replumbing potentially improve the pressure???
Access is good as the house is being partially gutted and there is a 3 or 4 foot void under the floor downstairs. The 3 rooms (kitchen, bathroom and ensuite) that need plumbing are all directly above each other too.
I hope that hasn't sent you to sleep??
I'm in SE London, if that makes any difference to your advice.
Thanks in advance
Steve
Here is the set up:
My dilemma(s):
Thanks in advance
Steve
