Should my surveyor have spotted this ?
5 Feb 2008
Berkshire
Hi guys
It turns out that two bricked up external doorways to our house have been bodged .... Poor pointing, possibly not keyed into surrounding brickwork and best of all ..... cement sacks used as a DPC !
We bought it last year and the survey didn't point any of this stuff out ....
Should this have picked up ? I'll try to get some piccies
Ta
Steve
It depends on the type of survey - ie was it something to be looked at, and if so whether the work was considered to be an issue or not.
A survey would not normally pick up cement bags as a DPC, or anything else as a DPC - how would you expect this to be seen?
Nor tying in of the infill panels - how would this be checked visually?
Poor pointing is subjective
The cement sacks are sticking out from the wall by about 30mm and there are cracks between the new brickwork and the original doorway
I'll try to get some pics
It depends what kind of survey you had.The basic ones are really just to confirm the value of the building rather than fault find
Nah it wasn't just the valuation survey. Its an old victorian place and a bit tatty so we paid for a decent survey - cost us a lot of money and now we find this :(
Might as well just wipe your arse with the surey report.
I certainly wouldnt pay for a more in depth survey again from a mortgage company.
You should never have got a survey from your mortgage company in the first place - you should have instructed an independent surveyor
Infill panels will crack - whether they are tied or not, and vertical cracking up the joint is not indicative of any lack of ties.
Bags sticking out of the DPC is not in itself evidence of the bags being the DPC
You only have a complaint if you have suffered a loss due the the surveyors negligence, not just because you think the work is bodged
But the question is, why didn't you see these things yourself, as presumably you would have had a look around the property you wanted to buy? Then you could have asked the surveyor to specifically comment on your concerns
Paper cement sacks or rubble sacks? Rubble sacks are made from heavy guage polythene and would certainly work as a dpc, though is it a bodge.
If you had a proper survey done (more than a valuation/homebuyers report) then you should be insured against this and be able to make a claim, however I doubt you'll get very far, but would be worth a letter, i made a claim on a guarentee once and they were more than happy to sort it out.
Hi guys
Ta
Steve
steve was they blue circle mastercrete bags ,if so there be fine , check the label :LOL:
If the dpc isn't breached, and the wall hasn't/ is unlikely to fall down, then I'd have to agree
