    Dismiss Notice
Shower Bar mixer problem
Discussion in 'Plumbing and Central Heating' started by andemz, 4 Mar 2012.
  1. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
    Hi all,
    The plumber has fitted the pipework for the mixer bar, the tiler has tiled over and left the hot and cold coming through the tiles, i have come to put the shower bar on and the plumber hash't fitted a wall plate fixing kit so there is a lot of movement. the pipework is behind walls which is not accessible and i now have tenants in the house, so i need to fix the problem with as little disruption as possible.
    I was thinking of fixing something behind the shrouds which would act as a support between the tiles and the actual mixer bar, but to be honest i would appreciate any advice please.
    regards
    Andemz
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Is it just bare pipework or has he fitted the doglegs on the pipework ?
  4. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
    If by doglegs you mean the fitting that goes from the pipework to the mixer, yes, he fitted them as well, he stated that when he was fitting them he got as far back as access would allow.
  5. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Yes but the pipes aren't secure they need wall plates that the doglegs fit into.
    Is it stud wall or block ?
  6. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
    Hi Seco, that's exactly my point. This hasn't been fitted, so is there anything that i can do now, that the tiles are on. i.e. retro-fit. Something that goes inside of the shroud to give stability or something.
  7. muggles
    muggles
    28 Oct 2005
    12,773
    Thanks Received:
    2,837
    Daventry
    Country:
    If tiles are reasonably newly fitted they should come off again without breaking, so take a couple off and do the necessary behind the wall, it's probably the only way to go from here. Alternatively get your plumber back to do it as he hasn't done it properly in the first place. I hope you didn't pay him very much, if at all....
  8. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Short answer no.
    what wall type is it block or stud ?
    Longterm is to remove tile/s and refit 2 wall plates.
  9. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
    It is block
  10. Sponsored Links
  11. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Ok thats my suggestion get the plumber back or diy and remove tile/s
    (you must have a few spare from new install)
    either fit 2 wall plates or just replace section of the pipes and fit external bar mixer kit.
    But either way the tiles need removing.
    The general idea is the mixer pulls on the wall not the pipework.
  12. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
    much appreciated. I will do it right and take the tiles off
  13. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Won't take long once the tiles are off.
    Pipeworks a doddle the times in the tiles ;)
  14. andemz
    andemz
    6 Mar 2004
    337
    Thanks Received:
    Country:
  15. muggles
    muggles
    28 Oct 2005
    12,773
    Thanks Received:
    2,837
    Daventry
    Country:
  16. muggles
    muggles
    28 Oct 2005
    12,773
    Thanks Received:
    2,837
    Daventry
    Country:
    Touche...mine are cheaper though ;)
  17. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    Yes thats what i was talking about above and as muggles said they do look great.
Loading...
Share This Page
