with manual shower mixers, you know if the cartridge needs replacing as the dial is stiff/stiffer to turn. are there any other symptoms that cause the cartridge to fail/that you know it is needing replacing? obviously on a thermostatic type the hot water will get increasingly hot but what about for normal manual shower mixers?
i have an aqualisa and i have noticed it is getting stiffer to turn recently. it is over 10 years old but looks clean and new still! but i have never thought too much of it. of course i will need to order another cartridge from a plumbers merchant or direct from aqualisa, but i would like to know if there is likely to be any other faults developing with it as it seems it is starting to fail ....
