Shower Floor Gradient
25 May 2009
London
I am planning to install a marble shower enclosure. Is there any building regulations relating to minimum falls for the shower floor? I know you can get formers with the falls built in but I think I'll just be using a marine ply deck set at an angle.
No Building regs. governing minimum fall of a shower floor but obviously you need one for water to drain away properly; there are regulations governing the fall/size/connection of waste. I would advise you re-consider using either a proprietary shower tray or wet room former. Ply is not a good idea for a shower base; it must be rigidly supported, sealed on the back & edges & tanked into at least the bottom 1/3 of the walls or it may only last a matter of months. Have a read through the archive tiling forum posts, lots of info in there to help you avoid making expensive mistakes on the rest of it. :wink:
If you do go with ply, you don’t need marine ply either, WBP is cheaper & made using the same waterproof adhesive on the veneers but without the decorative veneers on the outside.
