Does the boiler cycle on and off when only the shower is running? Could be a couple of things.
Firstly I'd get the boiler serviced by a recommended RGI, mention that there is an issue with the hot water to the shower. Hopefully he will be an experienced engineer and as such he should be able to fault find and identify what needs to be sorted out.
when only the shower is running (sometimes it doesnt even give hot water, ignition doesnt turn on), first it runs for a while and then ignition goes off . but when we keep the kitchen tap hot water running the ignition continues to be on.
i know i need to get an engineer but would like to have an opinion as well of what is going on and how much it will cost, how long it will take to repair.
