shower Install
7 Jun 2006
London
Hi All
First things first, I intend getting an electrician in to connect cable to consumer unit which is 100a but would appreciate your thoughts on me doing all of the donkey work first, any corrections or criticisms truly appreciated.
8.5kw shower, above bath, back of airing cupboard.
10mm cable from shower into airing cupboard running in mini trunking for 1.5 metres then into loft space.
Can I cable clip to joist or trunk for further 2 metres, not near insulation or metallic objects.
Drop down into 45 amp double pole isolation switch, ceiling mounted, carry on up through loft for a further 2 metres, then drop through ceiling down into mini trunking for 7 metres, through wooden floor board (now into consumer unit cupboard) to a 63 Amp 30ma RCD, then to a 40 amp separate MCB.
Thoughts?
Regards all
The work is notifiable so if you want an electrician to certify the installation you will be better off talking to one when actually looking at the site.
I stopped reading there, because I can't legitimately make any corrections or criticisms, and neither can anybody else here.
The ONLY person on the planet who can legitimately comment on what you plan to do is the electrician who you plan to get in and take over from where you think (probably mistakenly) is the point where you have to stop and present him with what you have done so far, but which is in realitiy (probably) way past the point where you had to stop and ask him.
Hi All
Thanks for the replies
I will definitely speak to a sparky and get advice.
I simply like most people on this site research in depth before committing to a task and obviously seeking help and advice from the true professionals, the work will be certified having spoken to my local building regs department.
Once again thanks for the replies it is very much appreciated.
