Hi experts, I hope you may be able to give me some plumbing advice.
I have just moved into a new house, which has a double shower cubicle in the attic room en-suite. We have used the shower a few times since we moved in, and yesterday we noticed a very small wet patch on the ceiling/wall of the bedroom below the shower room.
I have done an inspection of the shower tray and can't find any gaps in the silicone around the edges, however I noticed that the plug does not seem to fit flush against the shower tray on the right side, could this be the cause. The tray is very hard and does not move when you stand in it.
I am able to take the plug cover off, and inside is a removable kind of basket with a handle. If you remove this you can put your finger down and feel the bottom, it seems like the plug is some kind of chamber, no idea how the water escapes! There is a small lump at the bottom of this chanmber, not sure if this is a nut. Am I able to tighten this from the outside to make it flush, or would some sort of silicone around the plug be ok?
Thanks for any advice.
I have uploaded a few pictures, hopefully they work.
View media item 33924View media item 33925View media item 33926
