hi
having problems with my shower not draining quick enough, basically you end up standing in a few inches of water whilst showering, it isn't far off the top of the basin.
up to now i've put it down to hair and gunge etc, but after trying 2 unblocking solutions (which improved it slightly for a time) i decided to remove the front facia and try to remove the trap so i could give it a good clean.
this is where my problems start, when i unscrew the bottom of the trap there isn't enough clearance for me to remove it, is this normal or a gash job carried out by the installer? also the waste pipe coming off it has no clearance to remove that either.
things is i can see into the trap when i remove the strainer from the plug, and there doesn't seem to be anything in there to block it. could the blockage be further down the line somewhere?
the shower does kick out a lot of water is the pipe/plug hole size insufficient?
the house is a new build and we've been in about 10 months, i'm beginning to think there may be something else causing it.
any help or advice is greatly appreciated, many thanks for your time
